You're not a real driver till you've driven six months without any handbrake at all.
You kids, huh!
Handbrake - luxury. I did several months in a car without a clutch !
Strictly speaking it would work if you bled it, but by the end of your journey you had to change gear without the clutch. More to the point you had to start and stop without the clutch as well. It can be done, but I wrecked the synchro so had to double de-clutch thereafter after I replaced the whole cylinder rather than just the seals (again). When I later took the gearbox off for an unrelated reason I saw the bronze synchro rings had great chunks off them, but I made one OK gearbox out of two ropey ones. I think I reduced the life of the starter motor too - but cheap and easy enough on an old ford.
