T.M.H.N.E.T
- Northern Ireland
Also move it back a bit, would expect the rails to have markings.. Better yet, take and post a pic
Yep they do have markings, one every 5mm so I know how far I'm goingAlso move it back a bit, would expect the rails to have markings.. Better yet, take and post a pic
I will do, but I'll do that over the course of 2-3 rides as I don't want to shock my body with a big change, I've learned my lesson from that. Re-leveling the saddle alone should be a noticeable difference.Go back 5mm at least
I agree the position just looks wrong , i know we dont all agree KOPs is right but its a starting point so i dis thisThat's what I was thinking. I would want to be leaning forward and much more stretched out, not with a shorter stem giving an even more upright position! And the saddle a bit higher...
Only change one thing at a time, in small steps, and don't go crazy when testing new positions or you won't know if any pain is due to overdoing things or just by making the position worse!
Those look like his pants so hopefully not?!Off the bike
Stand up - bend and touch your toes
Then
Lie on stomach raise your neck and head and shoulders
As a rule of thumb position 2 will hurt if it's facet joints - and ease slightly if it's a disc problem.
Don't assume an upright position is better for your back. IME something is causing you're back to spasm - could be disc, arthritis, or just tight hamstrings.
I'd also throw £50 at some decent shorts assuming your riding with those in picture.
He’s 17 I think, arthritis is unlikely?
Much more likely a simple case of unconditioned new cyclist trying to overdo it on a poorly set up bike.
I hammered the hills yesterday really felt it on the hamstringsMissed that bit about op being 17
Totally agree on you're second point - overuse too much too soon most likely culprit. Position not noticeably terrible IMO - sure fine tuning required .
Cycle gently - get in an easy gear for the hills.
If you ignore the crank length bit, the rest is a very good explaination of 'Balance' on a bike:I agree the position just looks wrong , i know we dont all agree KOPs is right but its a starting point so i dis this
Looks like the OP is miles to far forward , there is an article about point of balance and saddle set back
https://www.stevehoggbikefitting.com/bikefit/2011/05/seat-set-back-for-road-bikes/
as a basic bike fit i like this
https://wheel-easy.org.uk/wp-content/uploads/bike-set-up-2017a.pdf
Thank you for that, I'll have a good look at it and will be following position advice on my near future ridesIf you ignore the crank length bit, the rest is a very good explaination of 'Balance' on a bike:
https://www.peterwhitecycles.com/fitting.php
I agree, the position looks all wrong, but can't yet figure why! Long legs and short back methinks, but certainly saddle UP first and then back for starters.
