confusedcyclist
Quick background, newish ebike, done only 800 miles. It developed a creaking sound when pedaling, but only when doing so with reasonable intensity to engage the freewheel pawl, and no creaking when coasting. I took it to dealer's workshop for repair. I suggested it might be the motor or rear hub but couldn't be sure, they tried their own process of elimination, and agreed with me and replaced the motor under warranty. When I called to chase up the work, they explained the motor was a mess and a gear inside had slipped and wrecked the inners. What baffles me is when I later went to collect it, they told me it was never the motor at all, there was nothing wrong with it (crossed wires with staff?). The mechanic who handed me the bike back said after fitting it a new motor they determined it was actually the rear hub that needed greasing. Expensive mistake on their part... Anyway, the motor was under warranty, so no fee for me and they claimed it was sorted and fine to take home. It definitely got a new motor because the serial number changed in my display!
I brought the bike back home in the boot of the car, but had to take the front wheel off to get it in. I was sloppy and left the wheel propped up against the side of the boot, on the way home, it fell over and bashed the derailleur and bent the hanger. No biggie, I have the tool and was able to get the derailleur aligned once again. Only now I'm riding it again, the original constant creak which I had assumed was the motor has gone, but now I'm experiencing a strange intermittent rubbing sound. It almost sounds like a leaf or debris rubbing between the tyre and mudguard, but it's happening too often to be a one off like that.
The rubbing seems to starts if I'm moving at high speed, but not when moving at a sedate pace. Sometimes a hefty bump in the road seems to trigger it, other times it just starts on its own accord. It's not disc rubbing, I'm certain of that. When it starts, it is constant, and doesn't go away when I'm coasting downhill, even at a slow speed. But it will go away if I come to a complete stop. If I stop jump off and spin the wheels at the side of the road, I can't reproduce the rubbing sound. Nor can I reproduce it in the bike stand. I'm completely baffled as to its origin. Any thoughts on what might do this? It went in with one problem, and seems to have come out with another, although I can't rule out my own handy work with the derailleur, but there's nothing to suggest it's the derailleur at all. Unless they did an extensive test ride on the bike, they may not have realised it came back with a problem, it's infuriating!
