ayceejay
- Rural Quebec
If the answer to every question regarding training or improving performance is "just turn the cranks" or "ride your bike" we could slimline cycle chat and do our bit for global warming.
Optimum for what, though...
Its what i find works best for me i can maintain a cracking pace and dont tire ive tried religiously spinning and its not for me.Given that information, I would suggest that the people suggesting you do something about your cadence are indeed correct and you ought to lift it a bit. Very few people would find their optimum cadence in that sort of ballpark you are riding at.
There are grinders and spinners, it was always thus. One or the other, or indeed something in between is more efficient for some than others. The longer you ride a bike, the more efficient you should become which in turn will determine your optimum cadence for the conditions. It is not rocket science, just listen to your own body. This question pops up more often than an epileptic toaster, as do the googled answers.
Ill just up the cadence, abit like a single speed to be honest, i grind the big ring on the flats and spin away up hills i use both extremes of the cassette but not often the middle ratios its never failed me yet so im sticking with itIf that's your cadence and it works for you that's all that matters, but what happens when the group you are with who are spinning suddenly up the pace and are now spinning in a higher gear, do you keep up with the acceleration ? are you able to spin at faster speeds if need be ?
Kind of agree with that. Obviously, I can go faster than my natural 83, but has a negative effect on my energy levels. A shorter faster ride results in me either pushing a higher cadence or a bigger gear, but this isn't my ideal cadence then.
