Does that pedal have an allen bolt on the other side of the crank?
If so, allen key + long length of suitable tubing + brute force
Me too.I'm surprised the kettle water go it hot enough!.
Me too.
We used to use what we called an impact driver - you whacked the end to shock the thread and the mechanism gave the fixing a tiny amount of twist at the same time.
I suppose that wouldn't work with a bolt because the impact would only transmit to the area around the hex head.
Should work with an allen fixing.
Don't hear much about them these days, although some come up on google.
Are they still in regular use?
https://www.toolstation.com/impact-driver-bit-set/p90581
Die grinder and reciprocating saw for me, they are normally hidden in the middle of the bikes!.
I think that's why splitters are popular to remove components on scrap cars.
You can often do some mild butchering to gain access which you couldn't do if the vehicle was going to be used again.
Depends which pedal!you have to use a left-hand-undo method (ie unscrew it clockwise).
