- Glasgow
Surely you're one that does not need rescuing lol!I wish @Pat "5mph" would come to my rescue
Don't agree. The GLW bought a bike through Evan's website. After a while, had to change the triple chainwheel. Tried using my trusty extractor, would't budge. Eventually I had to drift it off using a heat gun and some well placed hammer blows.By the way Evans are a decent group probably the best of the large cycle chain retailers, they value their reputation)
I always thought you were advised not to grease the taper? I'm assuming it was square taper.
Some companies use Loctite 'Studlock' on square taper cranks, I've come across a couple. All you need to do is heat it up a bit and the bond is destroyed so once it has cooled down the extractor tool will work.Don't agree. The GLW bought a bike through Evan's website. After a while, had to change the triple chainwheel. Tried using my trusty extractor, would't budge. Eventually I had to drift it off using a heat gun and some well placed hammer blows.I've NEVER ever had to do that with any of the many bikes I / we've had in the past / present. The chainwheel had obviously been put on without any lube involved. Contacted Evan's via their website and apart several 'Yes, we'll respond to your enquiry', replies, never got anywhere with it.
So our experience with Evan's is - unimpressed.![]()
In any event I don't think Evans were going to remove the crank and grease prior to delivery.
Front derailleur is misaligned and it doesn't look to have been 'knocked' as it would then be (mis)aligned the other way so possibly bolt not tightened enough on assembly.Possible Eureka moment? See photo below.
The chain appears to be squint and rubbing along metal on left hand side of this photo. I have looked and looked and the chain is still on the cogs? for the gears. Is the chain loose? Are the pedals out if alignment which is causing the chain to rub on the netal??
Going stir crazy. Need to be out on my bike!!
BTW these are quite tricky to position correctly unless you're experienced.
I am taking it in!!!! I just posted again in a last ditch attempt to see if I could resolve the issue long enough to get me and the bike safely over to the shop for it's service.Please just take it to a bike shop for a first service then book yourself on a bike maintenance course such as the ones run by Edinburgh cycle coop.
