uclown2002
- Harrogate
Thanks guys; hoping its a while before I need to do it
Thanks guys; hoping its a while before I need to do it![]()
There are techniques for getting tyres off and on rims without using levers. I usually carry some just in case... But havet had to use them for a while.
Thats me cursed!
i got a set of these back in jan, and they work well. I can change a marathon plus tyre with no major struggles, well worth getting.![]()
Funny how we all have slight variants on the method... I normally put one side of the tyre on the rim, then pump just enough air into the tube to get a bit of shape to it so it doesn't get caught under the tyre but not so much that the tyre is hard to fit over the rim, then work the other side of the rim over. For really tight tyres like marathon plus it helps immensely to have the innertube very very low pressure so the opposite side of the tyre can free up some slack. Once the tyres on I go round each side of the tyre wall squeezing it in to make sure I cant see any innertube caught between the tyre and the rim. Then pump the tyre fully to pressure and once done loosely screw the little nut on the presta valve, so it barely grazes the rim.Newbie question:- Is it normally easier to put the tube inside the tyre before fitting to rim?
Little tip I was shown as a kid but doesn't seem to get repeated nowadays - get three quarters through putting the last side back on, then take quarter off again and work in the opposite direction, the advantage is the last quarter has already been on, less chance of pinching the inner tube and generally easier.
I've got a pair of Lezyne levers. Not had a chance to try them out yet
