marzjennings
- Houston, Texas, USA
Not speed or forward momentum. Tests are generally a vertical drop to a flat, edged or angled surface with no horizontal movement at all.So what do you think they are tested for ?
2873828 said:There is a reasonable view that every helmet worn promotes helmets and brings the prospect of compulsion closer.
I thought you were an expert on the Snell standard and testing regime, Linford. Surely you should know the answer?
2875099 said:Momentum and kinetic energy are not the same..
2875095 said:Not an issue I have thought about to be honest. It's not as though you read stories about insurance companies arguing reduced compensation for no elbow pads.
2875197 said:I wasn't thinking about Hiviz because I prefer not to but yes, most probably,
2875225 said:Sounds reasonable to me, at least for any that you wouldn't want to be compulsory.
2875250 said:Net benefit? If so, what is the problem?
Linfords bumped his head.
I've already stated that anything up to walking pace, and I consider the risk to be no greater...anything more than that, and the risk goes up as the momentum rises Momentum = Mass x Speed
If I were to move my motorbike at anything more than walking pace, I would consider it entirely sensible to wear the lid. I am not the one arguing against the value of head protection for speeds above walking pace.
That's a definition of an artificial leg, but not necessarily a cycling helmet. Innit.
2875339 said:What, specifically, are you thinking of?
