I'm beginning to wish that I had learned how to make pancakes... (Or that the pancake-making friends that I spoke to a couple of days ago had taken my not-very-subtle hints!)
Reynard's French Crepes
4oz plain flour, 1 egg, half a pint of milk, pinch of salt, 1/2 tablespoon vegetable oil and optional, a little cinnamon and vanilla extract.
Sift flour & salt (& cinnamon if using) into a bowl. Make a well. Crack egg into well. Using a balloon whisk, whisk gently, gradually incorporating the flour. Once the mix gets a little stiff, start slowly adding the milk, gradually working in the rest of the flour. You should end up with a reasonably runny batter. Add the oil to the batter and vanilla if using. Let this sit for an hour or so.
Then, heat up your frying pan on a medium heat with a small splash of veg oil in it. Pour in enough batter to coat the bottom of the frying pan to a depth of around 2mm - a ladle works perfectly for this. Cook till top is dry and starting to lift off the bottom of the pan. Flip with a spatula and cook the other side.
The first one can be a bit iffy, but once your pan is right up to temperature, the crepes cook quickly and easily (couple of mins a side tops). The oil in the batter will stop them from sticking to the pan (I use a cast iron pan that I only use for pancakes) and you will only need to grease your pan the once, right at the beginning.
This quantity makes about 9 - my pan is a 10 inch one.
