Hi, for some background, I have been riding a Whyte Shoreditch hybrid bike for the past 3 years. I usually ride 30-40km and last year cycled 200km over a weekend without any significant pain / problems. This is the current bike showing the position of my seat / handlebars etc:
A few days ago I bought a Trek Madone as I wanted to start using a road bike for improved speed and performance. This is my first time using drop bars and I cycled 65km using the 3 different hand positions. After around 20km into the ride I started feeling a lot of low back pain, neck pain and shoulder pain. I had to keep stopping every 5km to stretch and rest. I usually have a fairly inflexible back - maybe drop bars weren't the best idea?!
I also think the reach to the hoods was probably a little far as my elbows are almost locked out.
I have measured my seat height according to the x0.883 formula and my seat should be a couple of cm higher. However that would mean I would be even more stooped down to the handlebars?
I've also calculated the height difference from my Whyte seat to handlebars vs the Trek and found to be similar the Trek handlebars should be around 60mm higher. I'm not sure if that is the correct way of calculating things or if the geometry of both bikes makes this calculation meaningless?
Unfortunately it appears the steerer has been cut short by the previous owner and there is only space for probably an extra 5mm spacer. I will try this and maybe flip the stem to give some extra height. If this doesn't work what should I do next? Buy a new longer fork? Use an adjustable stem? Or am I best seeing a bike fitter?
Thanks in advance.
Current position of Trek seat etc:
