Custom24
- Oxfordshire
Yes, I know what it is, but it's not relevant here, thanks.Never heard of cross chaining?
Thanks. What's NOS?grasping at straws here
bought a NOS chain
chattering noise
it was hitting the adjacent teeth on either side of the cog it was on... IYSWIM
bought KMC Z7 chain [recommended by Pat]................silence
using digital calipers , it was slightly thinner
However, while osbserving the chain and rotating the cranks forwards slowly, it may be that the links are not quite centered on the bottom jockey wheel, and in "slow motion", I think I can see the chain being sort of pushed sideways by this bottom wheel as it meets each link. Also, at normal speed, the noise appears to be coming from the bottom jockey wheel by ear and feeling for vibration. It's hard to say.
My plan now;
1. Get the bike back on the work stand and try to verify where the noise is coming from using a microphone.
2. Order rear hanger alignment tool and check/adjust. Also order a set of feeler guages and check that the chain does have some daylight to the neighbouring sprockets.
3. If still problem, order new rear dearailleur and hanger.
On this morning's ride, I didn't really notice the noise while riding, so it may be better than it was.
Thanks for persevering with me!I haven't noticed anything strange in your report. In case it helps there should be a gap of 6.3mm between every 2nd sprocket for the chain to fit, so only about 0.3mm gap shared by 2 sides if the chain is 6mm wide.
I think looking at an M10x1mm axle in the hanger from behind and from above when the bike is vertical on a stand should tell you reasonably whether your hanger is bent.
It might be worth checking the hub. The cassette should have no play against the locknut and freehub. A new freehub should have no play (except can spin in one direction) against the hub shell. The hub shell should have a little play and spin very smoothly and freely against the axle when out, and nearly as freely but no play when on (with a tight QR skewer).
In terms of chain on sprockets, I think you are saying that I expect a feeler guage of 0.15 mm to just about fit through the gap between the chain and adjacent sprockets. I guess a more important question is - what is the minimum distance there should be between the chain and adjacent sprockets to avoid a problem.
The axle in hanger did show some out of alignment as I mentioned before, but only from behind, not from above. I did think I could improvise a hanger alignment tool by attaching something to the axle, at right angles, which could spin around. But I think that would essentially be pointless and maybe misleading. Wiggle have a tool for £25.
I think the last part of your post goes as follows?
1. Remove chain.
2. Try to move cassette sideways. There should be no play.
3. Remove wheel, lockring and cassette.
After that, I'm a bit confused. I'm familiar with replacing a freehub (I've done it before), just not sure what you mean by "hub shell"
So, is this right?
1. Remove wheel
2. Try to move cassette sideways (inboard/outboard). There should be no play.
3. Remove lockring and cassette.
4. Should be no side to side movement of freehub (inboard/outboard movement)
5. Freehub should spin in one direction only.
6. Axle may have a little play with wheel out. Wheel should spin very freely. Similar to when I've adjusted cup and cone bearings in the past (although these are sealed cartridge bearings)
7. Put back wheel in bike, tighten skewer (mine is a security skewer, not a QR one, but similar). Wheel should now have no play on axle at all. Should spin freely, though. Easier to do with chain off I've found.
Thanks
The only other thing I noticed is that the noise improves if I pivot the derailleur forward to make the chain droop. It becomes almost silent when the chain has significant droop. I am not sure what this tells me, if anything.
................., I only have Lithium Molybdenum and Copper grease, and I don't think either of those are suitable.....................
I'm kind of happy because here the grease was just being used as an extra waterproof seal, not directly as a bearing grease (these are sealed cartridge bearings according to Whyte's site). So I think a waterproof grease was a good choice and the viscosity doesn't matter too much.i read the other day that lithium based tend to absorb water and should not be used for BB
i use ''Rock and Roll Web Grease' on all bearings
and CopperEase on things like stems, pedals
