steve292
- Weston-super-mare, north somerset
Agreed; BUT I am too inexperienced to know which ones are giving the best advice.
Well, for the right brake, there is no gap at all, so me thinks some adjusting is still in order.see post #28. also if the gaps (left and right) are slightly uneven, you can either live with it, or twiddle the black screws in pic 2 post #29 half a turn or so to "balance" them. just watch which way the gap moves as you turn the screw!
Rats. That was a great thought, and even I could follow the logic(!). However, I just tried undoing the quick release and nothing happened. So, although I am no worse off, I still am at the spot where squeezing the brake lever causes the left brake (when I face the bike) to move, but the right one is still against the rim.Just a thought: before twiddling further, is the wheel in dead straight? With weight on the bike, undo the quick release at the whel hub. If nothing happens, do it back up. If the wheel settles a bit, voila! Do it back up. You may then find the wheel sits more evenly between the blocks.
You won't go far wrong with the Park Tools clipsAgreed; BUT I am too inexperienced to know which ones are giving the best advice.
Good to know - for now and for the future. Thanks for that tip.You won't go far wrong with the Park Tools clips
R J the bike guy is very good as well.Good to know - for now and for the future. Thanks for that tip.
Perfect. Thanks for that. I shall make a note of it. Like I said earlier, utube is full of videos, but unless you know what to watch for, it is easy to follow something that perhaps doesn't contain the best of advice.R J the bike guy is very good as well.
Need to pick your brain (again). My problem now is that the right brake pad (with me facing the bike) is resting against the rim and I can't seem to get it to back off to allow sufficient space for the wheel to spin freely. I watched the recommended utube video clip (RJ The Bike Guy) over and over to ensure I missed nothing. Now that the noodle is properly settled in the linkage. (Whew! on THAT.) But now I am stuck again. Here's a summary of what I did to try and get the right brake (:This. If the brakes are then too loose, use the adjuster on the lever to bring it back. You are ideally aiming to have the lever approximately parallel to the bars when the brake is engaged. The adjuster has two parts, a barrel and a lock ring. Unscrew the barrel a turn or two and see how that feels. When correct, turn the lockring back against the lever housing. Voila!
