WillyWill
Regular
Clamp???Just loosen the clamp, allow a bit more slack in the cable, and retighten.
Clamp???
duhhhhOn the other arm to the noodle.
You are certainly not inferior, you are learning! And...duhhhh
I feel ever so inferior here. You people know too much about bikes! I truly appreciate your patience.![]()
duhhhh
I didn't go near it yesterday. Mother's Day, you know.@WillyWill how's it going?
Thank you, Alicat. I really appreciate your words - and help.Here's a fact @WillyWill - most of us were beginners once and some of us are still beginners at bike maintenance. And don't forget, the only dumb question is the one you didn't ask when you really wanted to.
Some of us like being helpful and are possibly a little bored right now so you are doing us a service by asking questions.
That's done; but now the brake pads are resting against the rim of the wheel, without me touching the brake lever. Wheel cannot spin freely now.The hex bolt on one of the arms is the clamp. Loosen off a little and let some cable slip through as you hold the brake arms. Then tighten up.
Google "adjusting v brakes" - loads on there
"Almost" Voila! Gee, I feel like I might be getting closer. Just went out, and followed your procedure above. Had to turn the adjuster as far as I could, but by doing that, I now have the left brake (when facing the bike) so that it actually moves when I squeeze the brake lever. When I am not squeezing the lever, there is a tiny amount of space between that brake pad and the rim.This. If the brakes are then too loose, use the adjuster on the lever to bring it back. You are ideally aiming to have the lever approximately parallel to the bars when the brake is engaged. The adjuster has two parts, a barrel and a lock ring. Unscrew the barrel a turn or two and see how that feels. When correct, turn the lockring back against the lever housing. Voila!
Ok so you need a little more slack, so need to loosen the clamp bolt at the brake caliper (wheel) end and let out a small amount of cable. if you let out too much, you can wind it back in using the adjuster on the lever that you just slackened (that's the fine tuner for adjustment)."Almost" Voila! Gee, I feel like I might be getting closer. Just went out, and followed your procedure above. Had to turn the adjuster as far as I could, but by doing that, I now have the left brake (when facing the bike) so that it actually moves when I squeeze the brake lever. When I am not squeezing the lever, there is a tiny amount of space between that brake pad and the rim.
On the other side though, that pad doesn't move at all when I squeeze the brake lever.
Attached. FYI, I was able to rotate the adjuster by the brake lever sufficiently that now the left brake (when I am facing the bike) will move a little when I squeeze the brake lever, and it does not touch the rim when the lever is not engaged. HOWEVER, the right brake pad does not move at all when I squeeze the lever. I cannot move the adjuster any further.Could you post some pics if you have enough permissions now? At the brake end and at the lever end.
