noisy brakes
gavroche
Getting old but not past it
North Wales
The brakes on my Specialized Allez are very noisy when applied. Is that normal of should I use different pads? The bike has only done about 300miles so nothing to do with wear and tear.
Norm
Noise can come from a million things, it would help if you said what sort of noise.
Squeaking / squealing can come from the toe-in / toe-out of the blocks on the rims. I can't offer much more than that, I'm afraid, beyond a little personal experience.
After a bit of fettling a few weeks ago, I had really squeaky brakes on my Tricross and a quick check showed that the rear of the block was much closer to the rim than the front (toe-out). I adjusted the angle so that the front was just touching before the rear (toe-in) and the noise went away.
However, noise can also come from contamination on the rims or the pads, loose calipers, metal-on-metal, headset issues... etc
+1 for toe in. I have a zip tie set so I can hook it over the end of the pad when I set my brakes, this gives just enough toe in IME and my brakes run silently.
Pads can help too, but set up is more often than not the cause IME :thumbsup:
