joggingbob
- Essex
Ok - this is probably a stupid question but.... A " No cycling" sign on a road means, of course, no cycling but assuming this applies from where the sign is placed by the road, when can cycling resume i.e. is it at the end of that road, (which may be very very long).
For example speed limit signs apply until you reach the next speed limit sign, (assuming you haven't turned off onto another road where a different limit applies but that is then normally signposted or noted in some way). A no right turn will generally apply to the next road junction on the right.... etc What about no cycling signs?
