Roadhump
Time you enjoyed wasting was not wasted
- The flatlands of South West Lancs
I think that is the next step tbh. Followed by the mech / derailleur, as they are the only bits that haven't been changed.have you tried a different shifter
^^ This. Derailleurs don't like much load when shifting. Front ones even less. Ease off and see how it moves.So try it just pedalling easy, does it shift ok ?
Try it as normal...is the result different ?
I thought of that, but it makes no difference whether the bike is riding on a high or low cassette cog.When changing up at the front, which sprocket are you in at the rear? If on one of the smaller cogs, it might give a better "grip" than when on the bigger cogs.
If you have a length of exposed gear cable running along your downtube you can pull it tight when riding. This will mimic the effect of changing up using the gear shift. If the derailleur moves up correctly when you do this, it demonstrates that the shifter is at fault (or the cable at the shifter)
If the front derailleur does not move up correctly it would demonstrate that the problem is with the derailleur. The front derailleur is such a simple piece of equipment that I am surprised it has caused so much grief but although it is simple, a small maladjustment can make a huge difference so it is worth checking that the derailleur sits parallel with the chain ring and hasn't rotated out of parallel. Likewise check that the derailleur hasn't slid up or down the downtube. With the derailleur adjusted so it is over the largest chain ring, the bottom edge of the derailleur should clear the top teeth of the chain ring by 2mm.
