LewisLondon
- SW London
Done! 60mm stem installed last night (and flipped) rather than the downward pointing 100mm stem that was on thereThink we've established that flipping the stem will bring the hoods no closer to the rider. Replace stem with a shorter one.
Saddle moved forward, not that much, but as much as I could.Only if you deliberately put your weight on your hands. Moving the saddle forwards allows the rider to bear more weight with the saddle and commensurately less through the arms/wrists/hands. Think about where the one plus two points of contact (PoC) are and how the movement of the saddle/rider's 'seat' moves the rider's CoG relative to those PoC.
This is the complement to what I said yesterday:
Next step: get her to test it. Then probably pick up the seat post and get that done.
