Yellow Saddle
- Loch side.
Good move. Here's a general rule for diagnosing a bent hanger. Gears will shift across a limited number of gears only, For instance, you can get it to shift from 9 to 8 and then it gets progressively worse after that. Fiddling with it can get it to shift from 1 to 2 and 3 but then it gets worse after that again.Cheers, I've ordered the Park Tools alignment tool, considering my other bike just came back from the LBS for hanger alignment I think it’s about time I invested in the hanger tool. I'm not in the habit of having mechanics look at things unless I'm stumped! Watch this space!
If in your case the gears shift perfectly across the range, up and down, something else is amiss but I don't know what. My guess is that the hanger is bent but perfectly in-plane or the actual derailer cage is bent, not the hanger. Your new ParkTool truth machine will reveal it all, I hope.
