Turbo Rider
Just can't reMember
- A compounded speck of dust
Yay Except for the extra price tag, of course. So boooo at the same time. Nice that it's sorted though.
New front mech and now a new shifter fitted and it still won't shift the fark up. The front mech cage is too far in and yet I'm turning the L screw clockwise and nothing is happening, the cage isn't moving...?This is a new derailleur FFS.
What is it I am doing so wrong?
You shouldn't need the cable completely tight. I think he means that if you can't move the gear lever, it's too tight?? Try loosening the cable with the barrel adjuster, but do it gently, maybe a complete twist at a time go give it some slack. Then turn the crank and click the gear lever. No action mean another twist and so on, until it rides up to the high cog. There will be a biting point, but you may still find the chain drops off again. Again, loosen the barrel adjuster until it finally sits on neatly. Then check that it stays put in all gears and try all gears on both cogs, for grind and / or drop offs. Might take some time, but when it does, you'll get a nice buzz about you If in real trouble and frrustration, might be worth going into an LBS and asking them to do it but insist that they let you watch...cost you a couple of quid at very, very most.
If I were you I would first measure the front chainline (i.e. the distance between the centre of the frame and the middle of the two chainrings), it should be 45mm assuming your bike has consistent road and not mtb components. Mixed road/mtb/brand components could give rise to phenomenon you are experiencing.
Then I would shift the front in onto the small ring and pull the front mech bare cable and see if the front mech would traverse outboard. The L stop screw should abut with the moving part of the mech when the cage inner plate is around 1mm away from the chain when the chain is on small front large back - it is easier/better to adjust the L screw to achieve this when it is not pushing against the mech (i.e. do it by pulling the bare cable while you turn the screw).
If the L screw adjustment is successful then use the cable adjuster to take up the resultant cable slack.
Then shift onto the large front and check/adjust the H limit screw to stop the mech overshifting.
If there is any doubt about cable clamping at the mech then best look up the online guide associated with the mech.
That's the problem, it won't shift and have tried it by hand. Either the shifter is busted and FWIW I think Jack above is right - am not convinced the first shifter was knackered and/or the front mech, which is also new, is kerbadgered. The limit screws are right on the inside and when moved along by hand have what looks like enough room to shift over..? The cable is taut, I rerouted it and the only thing that I can fathom is perhaps a cable misroute which would seem unlikely given the ease it managed an upward 180 degree turn through the Rival shifter. I'm at a loss.
It was a cable misroute which according to LBS is a common issue with SRAM. A google search came up with nothing when I searched for problems of this nature with Rival. The LBS had to take a plate off in order to plant the cable properly and recovering the one misrouted wasn't easy. Ridiculous but true.
Anyway thanks again for the input folks and RecordAce, again, thanks for all your time and input. Virtual pint for you.
Same LBS that sold you an uneeded shifter? Name and shame!
