Looks like it has been screwed in at an angle.
Houston. We have a problem.The pre-load cap is not seating against the crank face - do I have the wrong length pre-load cap?/ View attachment 136353
Assuming all else is right, it is safe to ride the bike
I'm pretty sure that funny metal thing, the lock spacer should be down not sticking up.
The tag actually stops the crank arm falling off too by the little tang in it sitting in the machined groove in the through shaft.Not really - no wheels, no brakes - actually not much else apart from a bottom bracket - Just come back from my NVLBS - I was told there are 6 different lengths of pre-load cap - hope I have the right one now
yup - but not while you are messing - there to prevent you over-tightening the crank bolts
It's like reading my attempts at "fixing things I don't usually fix"
- because in about ten minutes time I'm going to attempt to fit the cranks again - and this time it had better work
In an attempt for the world record for most OT post ever, I love the word 'tang'.The tag actually stops the crank arm falling off too by the little tang in it sitting in the machined groove in the through shaft.
Honestly Smiffy, you've filthied that frame up a bit.
