- South Manchester
A CX bike on the road will be as dead as a dodo. Same with MTB's - they are for off road.
Worked for me with the Genesis even though I didn't buy the stock bike I test rode. It confirmed the size I needed and also that steel is lovely on the roads (which were very rough around the Evans I used). It also confirmed that 105 brifters (10 speed at that time) were a no no for me as I failed to stop rapidly as wanted as I simply couldn't get the required power through the brakes from the hoods! I acquired the same frame and all the parts and got the bike built to my specPeople say you should test ride a bike before buying it,but can you really get a good idea if the bike's right for you or not just by going around the block, like most shops will let you do? I reckon you need a good 30 mile ride at least,before you can find out if it's worth buying or not.
That's pretty good, in my experience, they'll only let you do so on a dry day
Well that raises a few more questions.A CX bike on the road will be as dead as a dodo. Same with MTB's - they are for off road.
That is the point I am (failing) to make.........it just cant be done, can it.People say you should test ride a bike before buying it,but can you really get a good idea if the bike's right for you or not just by going around the block, like most shops will let you do? I reckon you need a good 30 mile ride at least,before you can find out if it's worth buying or not.
Yes........contacted Specialized and they passed it to Evans to reply.Have you tried to contact the suppliers/ manufacturers directly and ask where the nearest test bike to you can be found?
Interesting..............I will try the Specialized concept store.I have an LBS who want a 50% deposit for test ride plus a charge of Eur50 which is deducted IF you buy the bike. Jokers!
The Specialized Concept and LBS I use in the UK always offer me a test ride on anything for 2 days when I'm in UK, so no prizes for guessing my preferred supplier!
