gazza81
- Edenbridge
Well this is my problem, new crank arms are straight...
When I did my 1x conversion recently I used the triple crankset and put a single chainring in the middle position and kept my existing BB, for me that ended up being the best option
Not at the moment, I'll try and take one later.My BB is 73mm and 125mm so not sure getting 130mm will be enough of a increase to the width.
I cant picture what what you mean have you got a picture of it?
My other option is to buy an MTB crank that will be a bit wider, there's a Suntour xct for 20 quid it's a triple but they can be separated
Unfortunately my old crank is riveted together and the Rings can't be removed but that was what I want to try and achieve, riding in the middle ring all the time
It says recommended use is with 113mm bottom bracket, mines about 125.
Why does it make a difference? Surely that Arms just push onto the square tapered part?
I've seen a Carrera kraken frame i might buy because it's got a few bits on it that I could use and it's cheap
The Halfords website says sealed bearing bottom bracket, it's the right width 73 mm
Does anyone know if that would fit my frame?
Yeah im planning to use the cranks and im hoping they can be seperated!
