bozmandb9
Insert witty title here
- South Oxfordshire
In the 2nd World War scenario given in that article, the men lost weight by cutting their calorie intake. I fully understand the findings of what happens AFTERWARDS but that doesn't alter the fact that cutting calorie intake will result in weight loss.
Also that article is about fasting diets not increasing your exercise rate to match your consumption. If I personally want to lose weight, I don't change what I eat, I up my exercise levels. It seems to work. When I reach the weight I want to be at I revert to normal exercise levels which are enough to maintain a particular weight (I assume consumption naturally matched to my normal exercise level).
They did indeed, but they also became very ill, as well as gaining a lot more weight when they finished the restricted calorie period, so perhaps I should be clearer. If you want to lose weight in the short term, and possibly make yourself ill, then reducing your calorific input with no focus on quality of nutrition, or ensuring you ingest sufficient micro-nutrients will indeed make you lose weight (including probably lean muscle). If however you wish to lose FAT, and lose it for the long term, then you do indeed need to focus on quality of nutrition, and ensure balance and sufficient micro-nutrients.
