Not quite a guru but I've been doing some reading into this. The supply you have seems to suggest that it can be dimmed using PWM, although this isn't quite clear. Using PWM is going to complicate matters quite a bit as you need something to generate the PWM signal.Uncle Phil said:I'd like to be able to switch the light to low power - a full power setting for out in the sticks, and a battery-saving option for use in town where you don't need so much light. I'm sure there'll be a constant-current gadget that can do this, but I lack the knowledge to find it or to be sure of getting the right one.
Any electronics gurus have any advice?
I've been looking at other circuits that are probably less efficient, but allow the output to be controlled via resistors and switches.
The other alternative is to get a dimmable 'buck puck', but these cost around £20 each.
I've orderd some LEDs and some boards, so I'll play with them and then let you know what I find.
cheers
