My bike leaks..
yenrod
When I ride in rain upon placing the bike in el shed; water leaks out of a hole on the inside of the chainstay: obviously this helps it get out instead of staying in and doing some kind of damage what do you think I should do & do you think I should spray some oil/grease in their :biggrin:
I just can't work out how its getting in;
Possible areas for inlet:
BB - by cable guide?,
Down seatube ?,
Other...
Could it cause damage :smile:
It's an Alu'frame.
dodgy
The hole is there to let hot gases escape during welding/brazing (or whatever it's called, give me a break I'm not a frame builder :biggrin: ).
My bet is that it's coming in down the seatpost area, after all, there's a lot of spray thrown up there and it only has to find a slight gap to creep down - though generally seatposts are a good fit.
If you can be confident the frame is bone dry at some point (yeah right!), then you can seal those holes up - spray a bit of rust inhibitor in first if you like. But it's probably not a good idea to seal if water is getting in somewhere!
Dave.
Dave.
domtyler
Why spray rust inhibitor into an aluminium frame, rust is another name for iron oxide so should not appear on an aluminium frame unless something is seriously wrong.
dodgy
OK then, it was generic advice, replace rust inhibitor for 'corrosion inhibitor'. FWIW, I haven't bothered on any of my bikes (2 are alu and the other is carbon).
Dave.
domtyler
Dave.
Are you sure that Aluminium reacts with water? Can you actually buy corrosion inhibitor for Alu? In my understanding Alu forms a thin but hard oxide layer on contact with oxygen in the air which prevents further oxidation on its own.
dodgy
Dunno, I've seen that white powdery stuff form on previous alu bikes I've owned. No idea if it's water or not, see, I'm not a frame builder :tongue:
It will be coming down the seat tube - grease it up to seal it. Alu if it corrodes just looks messy, it won't affect the strength, as the oxidisation protects it also. Just a pain when it happens under paint, as you'll not stop it.
bonj2
it's not a problem to the soundness of the bike, it's just a bit more weight you're carrying around.
EDINBURGH
dodgy said:
Dunno, I've seen that white powdery stuff form on previous alu bikes I've owned. No idea if it's water or not, see, I'm not a frame builder ;)
That powdery white oxidation is caused by road salt, you should rinse off your aluminium frame after riding wet salted roads to protect the frame.
dodgy
It can be a problem if the water sits around the bottom bracket, some bikes have a hole leading into that area from the down tube and seat tube, too.
Dave.
