ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
That should be okay. As I wrote above, you just have to be very careful how you adjust the Roadracers.So, I could get the 5mm under the front brake caliper and just about under the rear brake bridge and caliper. A 6mm would fit between the tyre and seat tube.
front caliper 5.2mm
rear caliper 4.8mm
rear tyre/seat tube 6mm
sound like it should work?
You also have to accept that you will get grit rubbing under the guards from time to time. That problem is reduced if you make sure you clean under them regularly after rides otherwise they eventually silt up.
It was dry here yesterday and the guards were silent most of the time. Every now and then a tyre would pick up a fallen leaf and there would be a rustling sound for a few yards until it got spat out again. Obviously, if you got enough leaves in there one after another, they could start to become a problem.
As I said in my review, it's amazing that Crud have produced something that can fit into such a confined space, but that means that you don't have much clearance. I accept that there will be a bit of noise now and then, but it isn't there all the time - that would drive me loopy!
