Ming the Merciless
There is no mercy
- Inside my skull
Is it flammable??
Yes keep away from sources of ignition, don’t smoke etc. Fires can be dealt with via CO2, Foam or Dry Powder.
Is it flammable??
I use only KY jelly on mine. It gives a lovely smooth glide.
Water soluble so not much good in the rain.I use only KY jelly on mine. It gives a lovely smooth glide.
The only thing I know is the best place for it is on my todger.You seem to have advanced knowledge of KY jelly?
Is that a recumbent?
I use gear oil. It's inexpensive, doesn't fling, and the pressures a chain endures are nothing to the gears meshing within a gearbox. It doesn't smell brilliant, but if you're not into chain sniffing it's no problem.
