Thought you might have been referring to the flint catchers.
they are there to create a spark to light your fagThought you might have been referring to the flint catchers.
You can just chew em off easily enough.Awesome, thanks all.
Do you need to take a knife with you to cut off the plug (assuming road slick tyre), or just ride on?
The cutting section of pliers would do it if you carry a pair, but you can just leave the plug out, it'll wear down eventually so long as it isn't smacking your frame.Awesome, thanks all.
The "tail" which protrudes from the tyre will disappear inside five minutes. I wouldn't bother to cut it off.Awesome, thanks all.
I use mudguards that are fairly close. I've only ever used a plug once. From memory it rubbed a bit, then after a while stopped rubbing (presumably as it got flattened down against the road)Out of interest has anybody had experience of a plug and mudguards with tight clearance between the metal plates on the inner surface of the mudguard that carries the front fork bracket and the tyre surface. I wonder if this would catch the protruding plug and pull it out as the wheel rotates.
Have you never been caught out yet ?I'm planning on doing a lot of solo rides this year, and in the past I've just gambled that I wouldn't puncture with tubeless..
