Max heart rate question
So after two years...... I'm fitter and 4 stone lighter.
That's excellent and cause for celebration.
A
Andy_G
Staines
Initially I went by the 220 minus age but I know that's not accurate.
But my heart rate never really goes above 180/181, but I first took that when I started two years ago and now I can ride 100 miles more than then but my HR still reaches the same number.
400bhp
Sorry, I'm not sure I understand your point?
You hit your max when you do 100 miles? For how long? So what? How hard do you perceive you are working when you hit MHR?
I don't believe 181 is your MHR.
A
Andy_G
Staines
I've given everything going up hills and flat out on flt roads and it's never gone above 180/181 and I've just got back from a run and i hit 179.
My point is as I first said was I thought my max HR would go down the fitter I became but it hasn't.
Just to be clear - your MHR does not change with fitness. It will reduce with age, although the reduction is not accurately predictable or linear.
VamP
Banned
Cambs
Faster recovery is the aim!
It's a bit of a crude approximator really, bit like using BMI to establish how much overweight you are.
@OP honestly, don't worry about it too much. Your HRmax will not change significantly over time. The best you can use HR for is to work out where your lactic threshold sits, and build exercise zones around that, and even that is imprecise and laggy, and prone to outside factor influences.
Basically HR is a somewhat poor proxy for the work you're doing.
Andrew_P
In between here and there
Unless you are targeting particular high intensity efforts in your riding on a regular basis, you probably won't see dramatic changes in your recovery or RHR...
Of course that very much depends on the Cardio fitness in the first place. OP Surrey University will take you to your Max HR and VO2 max, if you fancy it
Unless you're a runner, in which case it's one of the few tools you have.
