Max heart rate question
Andy_G
Staines
Ive searched for a straight forward answer but i havent found one.
My max HR should be around 180bpm and in two years of riding it hasnt changed, i dont know if thats normal.
I thought that as you get fitter it might go down.
400bhp
I don't think it moves around generally?
RHR is the one that may go down as you get fitter.
Dan B
Disengaged member
Max HR might go down as you get older (though it's by no means certain). Getting fitter means that you can do more work at a lower %age of Max HR, or that you can sustain greater %age of MHR for longer, but as 400bph says the limit itself doesn't move around
MikeW-71
Carlisle
If you mean the HR that you record during a ride, it depends how hard you are working and it may not change much. I usually see a highest reading of 164 - 168, BUT that's not my Max HR.
In theory mine should be around 180 (220-age, which is a very rough guess) but I've never done a test to find what it actually is.
Rob3rt
Man or Moose!
Manchester
In theory mine should be around 180 (220-age, which is a very rough guess) but I've never done a test to find what it actually is and I'm not sure I want to either. The test involves working harder and harder and taking the HR reading just before you collapse/pass out/throw up (or all 3).
No it doesn't.
MikeW-71
Carlisle
Yeah, which is why I said it was a very rough guess :smile:
Rob3rt
Man or Moose!
Manchester
Not getting into the 220-age thing, simply not interested in this tedious debate, but to elaborate on my comment above (it was late last night and I was a little knocked about from racing in horrific weather so just gave up typing). Generally speaking you will reach your MHR some time before you pass out or collapse etc so there is no need to test until complete failure.
A
Andy_G
Staines
I'm not taking the whole 220 minus age thing as gospel just a rough guideline.
I just didn't know if my MHR would go down the fitter I became.
