WellyWonkey
- Denton, Manchester, UK.
Hi livpoksoc. Sounds as though you made the same mistake as me with being "drawn" to the hills. Everytime I went out I ended up in the Peak District thus becoming deflated with my progress. I then changed my training loop to one which was a lot flatter which in turn built up my stamina. My average was 10.5 mph until I changed and is now 15.5 mph (in 6 months). Even if you have to do a shorter, flatter loop 2 or 3 times on the same training day is more beneficial than struggling up and down hills. That will come later when your legs have toughened up.
Also, if you haven't got a track pump already then get one. Proper tyre pressure is crucial, the little mini pumps aren't good enough for the pressure you need. I'm still a bit weighty myself but have lost 2 stone in 6 months but my rolling speed definitely improved after I looked after my pressures better. Hope this helps. Keep up the good work, it does getter easier and more enjoyable :-)
