M520 vs M540 pedals
Are the 540 worth the extra tenner versus the 520...other than the approx 75g difference (not a massive difference when you weigh 92kg :whistle: )?
potsy
Rambler
My Armchair
Personally I'd go for the XT's and save yourself another 9g :tongue:
Deleted member 23692
M540s have a better quality bearing sleeve - metal as opposed to the M520s plastic. Ihe clipping mechanism is identical
I thought you had A600s?.
raleighnut
I do but they are an utter pain being only one sided!
There's a trick to use with them, set off with one foot clipped in using a lowish gear then after 2-3 pedal revs lift the unclipped foot up at the bottom of its stroke then put it back on EDIT at the top. Centrifugal (centripetal actually for the pedants) force will keep the weightier side of the pedal to the outside so its now the right way up.:biggrin:
Oddf you should say that. I got a pair of A600s earlier this year and I find them just as easy to use a my old M530s.
Asa Post
Super Iconic Legend
Sheffield
540s don't have flats for a pedal spanner - you have to use an allen key to fit or remove them.
520s do have flats.
I struggle to get enough torque to undo the 540s, so I prefer the 520s
They are always the wrong way round and fed up with faffing with my foot after every set of lights, of which there are squillion a round here! Have the m520 on the Pearson, easy peasy to use
520s do have flats.
I don't have a pedal spanner...I wasn't planning on fitting them myself!
potsy
Rambler
My Armchair
That's the reason I didn't go with those despite being lighter than the xt's, got the 530's on my commuter for the wider platform but can't say it makes any difference.
