M324 Shimano Pedals - Tension setting L/R pedal
gunja99
gunja99
Cheshire
Cheers guys, the fact couldn't get me foot out AT ALL inside and straddling a sofa :biggrin: :biggrin: worried me! Figbat reckons they same both sides, will have another look this evening :smile:
Drago
Tighten them up as far as they'll go - do it carefully, as the end of the plate where the screw sits can break of you're cack handed. Then count the number of turns as you slacken it up all the way, then tighten it by about a third.
Check the cleats are mounted properly and level, and inspect them for imperfections in the casting. Even good ones can be a bit rough, but a careful stroke with a file cures that.
