losing weight...
Wirefire
hi...ive taken up cycling again after 20 odd years to try to lose weight and get my blood pressure down...
do posters think cycling will achieve this...and will leisurely cycling be any good or do you really need to build up a sweat...
ive gotten into the habit of cycling for an hour every morning...maybe doing 10 or 11 miles...
im enjoying it...but have posters had any experience of whether it would be effective..
im 16 stone and 5 10 so really need to start losing weight...
appreciate any response...
calibanzwei
Warrington
Regularly expending more calories, doing any kind of activity, than you take on in food/drink will cause you to loose weight.
PpPete
Chandler's Ford
Try riding in the evening - especially as it gets lighter.
I find even gentle exercise after the last meal of the day to be especially effective.
You don't need to be thrashing yourself into a sweaty mess on every ride, but push yourself when you feel ready to do so - both in terms of speed and distance. Don't get hung up on goals of x miles in y minutes, or z kilos lost in so many months, just enjoy the progress you do make.
W
Wirefire
thanx for that...problem is i work nights....so i find its best straight after i get in in the morning...before i even sit down or have anything to eat...
if i sit down or get settled watching tv or something...thats it...im a gonner...
might start doing half an hour or so in the evening before i go to work.....
and yes i do find i eat something as soon as i get in after a ride...so ill have to start cutting that out....
Camrider
Cambridge
I'm 4.5 stone lighter than I was this time last year, and cycling has has been 50% responsibly for that. The other 50% has been through cutting out the crap in my diet.
You have made a good start, and I'm sure your millage will go up as the weather gets warmer and you get fitter, but you must also make sure you get your diet right as well.
Sittingduck
Somewhere flat
If you go out for 30 minutes at moderate pace then eat a snack (that you wouldn't have eaten if you didn't cycle) you will not lose weight, IMHO.
Cycling will be good for your fitness and of course it burns calories but you need to obtain a calorie deficit, by taking great care of what you eat. Don't be like I was and thought that because I was cycling a fair bit, I had the right to stuff anything into my gob (oh er, Missus). Be sensible about it and try to monitor any progress regularly, then tweak to adjust. FWIW, I would look into doing some easy rides and some harder ones, so you don't get to used to the same old mediocre pace.
Good Luck!!
ColinJ
Puzzle game procrastinator!
It is easy to mistake thirst for hunger so make sure you are drinking enough water. You shouldn't need to eat extra for an hour of cycling - that is a good length of ride to burn a few hundred extra Calories without you having to eat more to keep going.
When you start doing long rides (assuming that you do!) - you will eventually have to start taking in extra Cals to replace some of the glycogen that you burn, but you don't want to overdo it and replace the fat burned as well!
Someone of your size cycling at about 11 mph might burn about 500 Cals an hour so if you don't replace those Cals, 7 hours would be about 3,500 Cals or about 1 pound of fat. That pretty much agrees with what I've found - I lose about 1 pound for every 100 miles ridden, but I do take on some extra Cals when riding more than 30 miles.
If you find yourself running out of energy while you are riding, allow yourself upto about 250 Cals an hour. You'd still be burning 250 Cals or so of fat an hour.
Doing 7 x 1 hour rides is probably better for weight loss than 1 x 7 hour ride because -
  1. You can do the 1 hour rides without taking extra Cals in, whereas it would be very hard on a 7 hour ride
  2. Each ride boosts your metabolism for a while which increases your fat-burning. 7 metabolic boosts a week is better than 1 boost a week!
(I should take my own advice! I don't ride for days or evens weeks at a time and then go out and thrash myself. It's not a sensible way of going about things ...)
smutchin
Cat 6 Racer
The Red Enclave
It's more the unnecessary snacking between meals that you need to cut out (if that's a problem for you), and eating less overall - smaller portions at mealtimes.
I've lost 10kg in the last six months simply by doing more cycling and being more careful about how much I eat, so I should say it's possible.
d.
Nosaj
Rayleigh
You cannot out exercise a bad diet
You cannot out exercise a bad diet .... in the long term
Hope I've made my point.
Me 5'11 16.5 stone now floating around 12 stone. Main exercise cycling. What you are doing will definately work an hour of cycling should see your weight drop off provided your nutrition is dialled. The more you dial your nutrition the more you will get the body shape you want. Speak to any bodybuilder/fitness model I am sure most will tell you that diet is just as imporant if not slightly more so than the exercise they do. I learnt all this the hard way.
Step 1. Work out your basal Metabolic rate good explanation here
http://www.shapefit.com/basal-metabolic-rate.html
This will give what calories you need to consume to exist each day. Extremely roughly speaking 12-13 calories per pound of body fat to lose weight. This goes on to explain energy expenditure requirements dependent on your lifestyle.
Basically yes Calories expended more than calories taken in you will lose weight, however you could get all your calories froms Mars bars, Monster Munch and mince pies; which is not really a good sustainable plan.
Macro nutrients become your friend:
http://www.freedieting.com/tools/nutrient_calculator.htm
Best of all some sites will track all this for you, you set up a food diary, track your macro nutrients and it will show you your protein carb fat ratios that you can tweak over time.
http://www.livestrong.com/myplate/
Obviously this is in the extreme and do not worry to much to start with. Most of us know what we should and shouldn't eat and what you need to cut out so start there. If you stick to clean, unprocessed complex carbs with a low GI Wholewheat Pata, bread, noodles (you can get a GI diet book from your library which gives really good examples) whack in protein, Chicken, eggs, tuna. Throw in lots of veg (virtually unlimited 50 calories a cupful basically), and some fruit - You will also need some fat Omega 3, Olive Oil, Flaxseed.
If you start cycling further distances carb up a bit the night and morning of your runs porridge or oatmeal becomes your friend.
As an idea this is what I ate today
Breakfast skimmed milk, banana (green ish) oatmeal and whey protein smoothy sounds awful but is actually quite nice.
AM Snack rice cake and apple.
Lunch Chicken wholewheat noodles, bean sprouts, mange tout, with bit of lettuce on the side. A medium Orange
Snack nuts and raisins
I feel pleasantly full right now at 18.03 pm
Dinner about 8pm for me will probably be something like more chicken a very small amount of carbs such as rice and loads of veg perhaps a yoghurt afterwards
Notice no bread....
Just a very simple example I try to eat like that around 90% of the time and for the other 10% I do pretty much as I please now. I must admit that the diet I am following is a bit anal and compared to where I was 3 years ago poles apart but I still feel I have a way to go yet.
It is a long game however just start with short little steps, cut out the empty calories here and there.You probably know what you should really cut out, eat little and often and stick to the cleaner food and you will be amazed at what happens. There is some food now that I cannot stomach. I used to love the odd McD's but truly I cannot eat it anymore, same if I have too much chocolate or sweet stuff (actually the portion as I used to eat) I really do feel sick afterwards.
If you are worrying about feeling hungry don't once you eventually wean yourself over to clean food and you get to the point where you have to consume more to meet your energy requirements for the extra activty you do you will really, really, really struggle to consume your calorie requirements in clean unprocessed foods.
Hope this helps and good luck with it all, look forward to hearing you are now 12.5 stone at the end of the year!
Nosaj
Rayleigh
Don't cut it out, swap it to a banana or some skimmed milk with whey protein or even one of those skimmed mik chocolate shakes or my breakfast smoothie something like that. Your muscles need to replenish their stores after exercise just not with Jaffa Cakes or something similar. You can even buy specific recovery drinks (not red bull or lucozade)
Not to disagree, knowing nothing about health/fitness/diet etc, but...
In a year I've lost 2 and a half stone, and the only thing I've changed about my lifestyle is cycling. I now commute to work and ride on rest days too. I have an AWFUL diet, reguarly eating rubbish, at awful times of day and night, but I haven't changed that at all!
