[QUOTE="Shut Up Legs, post: 5701571, member: 9294"it doesn't change the depressing fact that they're both reinforcing the myths about hi-vis clothing and helmets, and helping suppress cycling.
And it is language like this that perpetuate things. There is no myth about helmets or hi-vis clothing. There are two clearly opposing points of view. There is a body of evidence that supports both narratives. That being said, this is the law. If a Barrister feels that most reasonable people would support the view that a cyclist should try to be visible and to wear a helmet then they will make use of that.
In this case they use it to reinforce that the cyclist was visible. Had the cyclist been on a dark bike, on a dark street, at night with no lights then they would have taken the line that the lorry driver could not see the cyclist, and used that as a defence point whether it would have made a difference or not.
All of the dashcam and cyclists cam footage will be admissible, it is up to the barristers as to whether they rely on it. I suspect that the defence will argue that the cyclist darted in front of the lorry into the blind spot rather than braking and coming to a halt, while the prosecution will likely argue that the cyclist had insufficient time to stop and was visible (dependent on whether the dashcam footage supports that).
As for the "blind spot" argument there is a great video that illustrates just how much a lorry driver can / can't see.:
View: https://www.youtube.com/watch?v=lV-rhiGRFTE
Personally I don't think that visibility in terms of high vis can always be said to be an irrelevance. In this case I think it is. From the looks of it, the trial could be a close call. Remember the Jury has to be sure beyond reasonable doubt that the driver was driving below the standard expected of a competent and careful driver.[/QUOTE]
This has nothing relevant to the accident that occurred, the cyclist was travelling along a main road (in the cyclepath) when a lorry turning left out of a side road drove straight into him. The driver claims that the cyclist was obscured by his mirror array. The witness in the van that was behind the lorry claims that instead of stopping at the 'give way' the driver "lurched forward'
