- South Manchester
I can get my cleat covers over the look keo cleats that have the rubber grips... is that what you mean?Btw cleat covers won't work if you have the anti slip cleats with the rubber inserts.
Yep, I used to use the covers with the standard cleats then went to the ones with the rubber grips and tried to put on the covers to no avail.I can get my cleat covers over the look keo cleats that have the rubber grips... is that what you mean?
However bear in mind with the grippy cleats that after a few weeks of regular use the grips on your standing/unclipping at lights foot will have worn off anyway!if you use the non grip cleats they are very slippery on smooth café floors, and it might be safer to use the covers.
I don't find that. There is usually some of the grippy stuff left somewhere when I have to change a cleat, but then, I don't commute so maybe not so much 'foot down'.However bear in mind with the grippy cleats that after a few weeks of regular use the grips on your standing/unclipping at lights foot will have worn off anyway!
Maybe you have a lighter step than me?!! Guess which my 'put down' foot is?!I don't find that. There is usually some of the grippy stuff left somewhere when I have to change a cleat, but then, I don't commute so maybe not so much 'foot down'.
these look like the job
http://www.ebay.co.uk/itm/Shimano-R...ing_Tools_RepairKits&var=&hash=item2c74b8257d
Cheers Ed
Cheers Ed
Look good to me.
