Ajax Bay
- East Devon
I thought this is what you meant but wanted to be sure.When I tighten the QR lever it seems to seize the whole wheel in-between the pads (i.e. wheel doesn't spin) - then I release it, adjust again maybe loosen the QR a touch, and when its clipped back in, wheel now spins (more freely).
Your hub is too compressed - that is why the wheel is 'seized'. There are two bearing races in there and they have to be 'mummy bear' compressed. And that needs to be the state when the QR is cinched. So a tiny bit loose when the QR lever is not pushed 'down'.
If you can adjust your hubs you can solve this (but). Tools and technique depend on the type of hub (cup/cone or pressed in).
And finally, the image you shared shows your QR lever not sufficiently pushed in: it needs to go beyond the perpendicular (to a plane parallel to the bike's plane (if that makes sense) - parallel with one of the spokes, ish.
"Best suited" as in 'not really suited for use with drop bar STIs'. This is not really a 'flex' issue - it's a cable pull and geometry issue.The brakes on this model of Tri-Cross are original and are compatible with drop and flat bar brake systems.
However, they are probably best suited to flat bar brake levers and not STI levers. The later V-brakes were slightly shorter to reduce any flex
