mickle
innit
- 53.933606, -1.076131
Why do bikes (along with every other veehickle I can think of) have rear brakes?
If you are a driving instructor and you told someone to use maximum brakes what do you think the person would do? Maximum means all of. Optimal means the perfect amount of... in this case force to use in order to bring the bike to a stop. I still wil continue to use both brakes as the CTC taught me for both on and off road riding.
I said maximum braking, not maximum brakes. And with driving you have no choice. You only have one pedal but perhaps you would yank on the hand brake as well if given that instruction.
Whether you continue to follow the CTC method or not is your prerogative but you have still not addressed the question of how you can get harder braking than the point at which the rear wheel is lifting off the ground and what role the rear brake has in that situation. Its a matter of simple high school physics and mechanics, nothing more.
I am not disagreeing with you that once the rear wheel leaves the ground it is useless. What I am saying is there is no reason why you should have to brake that way.
I still say maximum brakes means all the brake power you have. It's like saying I drove a car at max rev but still had some revs left.
Stop moving the goal posts. I have consistently said "maximum braking" which you are now trying to change into "maximum brakes" as your escape route.
So stop ducking the question and tell me how you achieve greater braking than what I have described as maximum braking. You are objecting to me calling it maximum braking which means you must envisage a situation where you can achieve more braking than what I am calling maximum. So tell me how you achieve it.
I suspect the reason you won't is you can't as it is the maximum despite all your protests otherwise.
Easy - you can achieve greater braking by pulling full on the front brake only and going over the bars - That is max braking / max brakes. It is not optimal for an emergency stop however. The word maximum means all, full out, no more left. If you say max braking by definition it means you can brake no harder. Change it to optimal braking and I'll agree 100%
That would not be braking. Call it maximum effective braking and people would understand.So you are playing silly sematics. You know you can stop even faster by riding into a brick wall?
Optimum braking by your standards will still not include the rear brake (in a road situation)
Because they dont want people to go head over handle bars and get hurt.So why do the CTC amongst many others teach emergency stopping using both brakes.
Your front brake will stop you in half the distance of just the rear. The front brake is most affective at the point just before the rear wheel lifts off the ground, at that point using the rear brake will just lock up the rear wheel.
Yes so the idea is to keep both wheels on the ground by using both brakes.
Which means you are not slowing as quickly as you could. The physics doesn't allow it to be otherwise on an upright. I don't know about you but if its an emergency I want to be able to stop as quickly as possible, especially as it can mean the difference between hitting or being hit and not.
So the other idea is to practice braking so you don't go over the bars using just the front brake.
