Lights. CREE XML XM-L T6 / U2 etc Thread
Nigelnaturist
Pontefract
My first one, I left on full to test and the torch unit overheated after about 50 mins, not something you normally do, but I thought i had a fully charged battery when i went out the previous evening and it only lasted 25 mins on full hence the test, conclusion was the battery couldn't have been fully charged. So just a word of warning.
Just received a Jexree Owl, twin XML-U2 just under £20 on Ebay. http://www.ebay.co.uk/itm/281423636522
Feels very solid, heavier than a Solarstorm X2. The things that makes this light different is that each outer ring at the front contains a set of white led's that light up using the left hand switch. These can be on at the same time as the main lights or on their own. They can be on constant or flashing, the flashing mode is extremely distinctive, being a pair of flashing rings.
BTW, this is for the light head only, no battery pack included.
Here is a video taken with my phone, of the outer rings only
50000tears
Weymouth, Dorset
Made the stupid mistake of buying one of these
http://www.ebay.co.uk/itm/CREE-XML-...ing_LightsLanternsTorches&hash=item2ec3e8eaee
Without appreciating that I now need to buy a battery pack and possible a small top tube bag to pop it in! Can anybody save me from my own stupidity and point me in the right direction the power pack as I can't find what I need anywhere. Either that or or will have to go begging back to the seller!
Please note the light connects by way of USB plug.
They look good, particularly the Topeak bag, that's a popular choice for carrying a battery on the top tube. The Anker power bank contains two 18650 sized batteries and should give you about 90 minutes Max on high power
50000tears
Weymouth, Dorset
Thanks again much appreciated. I expect only to be using the low setting as that is plenty bright enough so hopefully will be good for 2 hour winter rides.
mynydd
I've a cree 6, which lasted about two months before the battery stopped charging. If I plug it in the charging light goes green, suggesting full charge, but it doesn't power the torch. Connected to a different battery it works.
Any solutions? Or failing that a source of a compatable battery?
Thanks
Nigelnaturist
Pontefract
Thanks
Just buy another one, there are battery packs on ebay if you look, if no one has pointed you in the right direction I will later, in a bit of pain at the mo.
mynydd
Thanks, I've just bought another which is how I've found out the torch part was working. Just wondered if there was any solution - so I could have a spare. Hope you feel better soon
Nigelnaturist
Pontefract
@mynydd I goosed a front light last year testing the battery, it overheated on full with no air flow to cool it, I had gone out with what thought a fully charged battery it lasted maybe 20-25 mins mainly on full, as I was on dark lanes, so I got a new light, but both battery packs have lasted, on is two years old and the other nearly a year, not had any problems, however they haven't been fully tested in recent months, but seem to have held a charge well, was out today with one on flashing 15 miles or so no problems, this was the newer one.
