jann71
- West of Scotland
for the water bottle youll need to drill a hole into the bidon or find a screw on top different to a bidon
lol, that defeats the object.The flash is a bit hectic. I had a couple pedestrians cover their eyes lol
I agree. It's borderline offensive.I won't be using it. The Magicshine has a standard on/off type flash, but this T6 clone is bonkers, absolutely horrible. I can think of two uses - if there is ever anyone that jumps out on you, just switch this mode on and their eyes will be toast, or if you get badly cut up by a SMIDSY - a quick flip of the flash mode might remind them you were there.
Otherwise, useless.
Totally agree, not to be used for normal riding , I do like the idea of a quick blast for SMIDSYs thoughor if you get badly cut up by a SMIDSY - a quick flip of the flash mode might remind them you were there.
Otherwise, useless.
Ran mine all week on the lower setting which is absolutely fine for an urban commute, that's 9 rides of 45- ish minutes and it lasted all week without recharging.
Just turned it up when I went through the unlit park for a couple of minutes each day.
Well impressed for the money![]()
See my post on page 7 Wanda, £8 from CRC though you need a longer screw from the spares boxThe large O ring died just before I was due to leave for home. The small O ring is a tad small for my bar-taped drop handlebar. I've got another O ring I can use from my 'other' light but wondered if there is a more secure alternative out there?
