I got the BLT firewire today and have been out for a ride this evening in the dark on some fairly minor country lanes, and I have to say it's quite good actually.
It's not exactly like a floodlight like when you've got full beam on when driving, but it casts enough of a beam to see where you're going, which is the main thing. Prob'ly not really wide enough a beam or bright enough for MTBing, and darkness still a bit of a burden on fast road descents and/or where there's lots of tight bends, but it DOES light the way, and that's the main thing.
One thing I have to say about it is it does seem extremely well made, the battery case and the light body are really nice polished/'mottled' metal, and are very light, looks great and is very elegant and sleek. The 'stick' battery holder fits onto a pump bracket like I thought it would do, and the 'coil' cable is just about the right length.
Some reviews said the mounting was a bit flimsy - while it is fairly thin plastic, and the method of fastening the strap isn't the best in the world (it just 'clicks' through like a cable tie but that can go both ways) it does attach well enough. I thought it was going to be a bit of an arse removing it from the bike every time because the light itself doesn't unclip from the mounting, but it's actually fairly easy to unscrew it at the front and remove the mounting that way with the strap still fastened, and it does up again tight enough. Only real problem I encountered is that it kept pointing itself too much to the left 'cos it's touching on my cables and it does swivel fairly easily, I think this is 'cos it's fairly light really - but I'm pretty sure I'll be able to sort this problem out.
Beam shots compared with smart polaris 2:
here is the smart polaris 2 (5 LED):
BLT firewire 4:
You can see how when shone at a darkened, not particularly reflective object, like this corner of a wall in an overgrown yard, it's clear that the smart polaris throws off little sub-beams at angles to the main one, due to the optic it uses and the fact that it's got 5 smaller LEDs as opposed to 1 bright one.
But, the smart polaris 2, while nice for commuting in lit areas, when I tried to use (well,
did use it) on dark country lanes I got the feeling I was cycling blindly and randomly into the blackness, while with the BLT i did have a reasonable enough idea of what was ahead in order to go along at normal pace.
