Short answer, it’s because early threads were cut on a lathe with a tool working towards the headstock and so easier to make right handed.As a lefty, I've never felt at any disadvantage using nuts, bolts, screws or spanners. Sorry... but I'm calling BS on that one.
I mean... are bolts designed to be tightened or loosened? Are righthanders at a disadvantage when doing one but not the other??
As a lefty I have no trouble at all mounting from the left, in fact when I’m in a rhd country I have trouble mounting and (especially) dismounting on the rightAm i missing the point is is that a total contradiction... if it makes no difference then why move it?
Anyhow i seem to recall it being mentioned that most people mount their bike from the LH side. Being a lefty I simply cannot mount my bike from the left. I will fall over. So I mount it from the 'oily' side...maybe that's why the drive is on the right and not the left.
yesAm I missing something obvious?
Thanks, that's good to know.
Think about it, For Dahon type fold in half, it couldn't possibly cover the chain etc as the crank set etc wouldn't allow it fold, that's why the frame fold back on itself to the non drive side.Thanks, that's good to know.
The Brompton style fold - 3 way allow this as its just the front wheel that is sitting over the "tucked under" rear wheel and chainset.
Not just that, but if you flip the wheel, you would be turning the cassette, block etc counter clockwise. Same as back pedaling or freewheeling. So you wouldn't go very fast! Would need redesigned freehub.Isn't the chain traditionally on the right because older sprockets were screwed on? So pedaling will only ever tighten them. Put them on the left and there's the potential to loosen the thread in operation
