winjim
And all in the space of only 2½ years.From torque wrenches to Mini Metros![]()
Yes: after the Lazarus rousing of the thread I thought people were desparate to torque during lock down. But clearly motor cars were more on people's minds. I know mine is flashing all sorts of lights at me, saying 'take me for a long, hot engine/exhausting drive, please'!all in the space of only 2½ years.
I'm pretty sure I was responsible for the resurrection, my mention of Ernest Saunders in another thread may have contributed or the mere business of surfing the site while suffering from cabin fever, probably the latter.Yes: after the Lazarus rousing of the thread I thought people were desparate to torque during lock down. But clearly motor cars were more on people's minds. I know mine is flashing all sorts of lights at me, saying 'take me for a long, hot engine/exhausting drive, please'!
No, he's alive and kicking and has revised history and court transcripts to say that he never claimed to have any degenerative brain disease. I'm pretty sure I read that co defendant Gerald Ronson gave old Ernie the idea for the Alzheimer plea.Is Ernie still suffering from court-fright or is he fit and well? Surely Old Father Time welcomed him long ago.
There is also a difference between ‘wet’ torque values and ‘dry’ torque values. If any given bolt is lubricated prior to having a particular torque applied, it will be considerably tighter than the same bolt torqued ‘dry’. Most torque values assume ‘dry’ torque loading.
In principle yes, but I recall it’s usual for a torque value to be given as a ‘wet torque’ value when the thread to be torqued must be lubricated. My aeronautical engineering studies were a very long time ago now, hopefully somebody more up to date and knowledgeable will be along shortly.In layman's terms for instunce
If a value is 5nm
Should you torque a "wet' bolt to say 4.5nm
Thank
I do. They're pretty common to save a few grams and/or avoid rust. Some, like stem expander bolts, save quite a lot of weight.Hands up who uses titanium bolts; and why? ('CycleChat' cycles not b****y cars or motorbikes.)
My apologoes for shouting ...I was not aware that big letters meant shoutingWhy are you shouting? Why are you hectoring people to use a torque wrench for every fastening? Their use as a matter of routine makes sense for bikes and components not made of metal. Most bikes and components are, however, made of metal.
What's a "battle gone wrong"?
Before I had a torque wrench, I used something similar for small M5 bolts. "Finger tight" was with the wrong end of the allen key, as hard as I could turn it (which is not very hard, given the tiny leverage). Then half a turn using the key the normal way round. I must try this and check the torque, but I bet it's in the right range.I'd just like to point out that 'fingertight plus a quarter turn' is a recognised torque setting in my field. In fact the fitting in question does have a specific torque wrench but the manual states fingertight plus ¼ so I guess that must be how it's calibrated...
