Profpointy
Good point, I should have expounded. Whenever there is a single bolt in a stem, it is usually a 6mm bolt and over torquing it is less critical than over torquing bolts in pairs or double pairs, because the latter are invariably much smaller, with 4mm diameters. The larger the bolt, the less critical its torque becomes (wrt to the bolt, not the device it is clamping) because the margin of error is so much larger.
Even this may not be so obvious, but the area of a 6mm bolt is 114 mm2 whereas the area of a 4mm bolt is 50mm2. That 2mm makes a huge difference. Strength is analogous to area.
On some stems, there are 4 x 4mm aluminium bolts. Those are super critical.
Can I ask what you mean by area in the numbers above ?
