Wheel is an R500 about a year old.Sounds like you need a spacer to me. I'm not an expert in freehubs, but if you post more information such as number of speeds on the cassette, age and type of wheel, others may be able to give you more information.
No, you don't need a chain whip to tighten it, just the nut wrench. You'll be working against the freewheel if that makes sense so can just tighten it up.I wish I had read these replies last night!
This morning I was in top gear on the bike (Allez) and I suddenly lost all traction. I thought the chain had snapped (but I had replaced both the chain AND cassette the weekend before, so both brand new).
Looked at the cassette and the smallest ring(s) was completely loose. Managed to ride on to work in one of the lower gears (will have to do this trick again for the ride home).
I did use a lock nut wrench to tighten the lock nut on, but i didn't use a chain wrench to counteract it in the opposite direction. Could that be the cause?
Need to take the wheel off later and have a closer inspection.
Thanks. Then I'm really not sure how I got it wrong. I used one of these to tighten the lock nutNo, you don't need a chain whip to tighten it, just the nut wrench. You'll be working against the freewheel if that makes sense so can just tighten it up.
What cassette are you using? If it's a Shimano 105 for example, there's a small spacer that should go between the largest cog and the wheel. I fitted a new cassette at the weekend and almost missed the spacer in the packaging. It's metal rather than the plastic spacers used across the rest of the cassette.Thanks. Then I'm really not sure how I got it wrong. I used one of these to tighten the lock nut
This is the cassette I have http://www.ribblecycles.co.uk/sp/ro...o-9-spd-hg50-sora-tiagra-cassette/shimcass905What cassette are you using? If it's a Shimano 105 for example, there's a small spacer that should go between the largest cog and the wheel. I fitted a new cassette at the weekend and almost missed the spacer in the packaging. It's metal rather than the plastic spacers used across the rest of the cassette.
Talking of spacers, have you put them in the right places?
Yep, that'll need a shimano specific locking nut adaptor (about a fiver from any LBS)This is the cassette I have http://www.ribblecycles.co.uk/sp/ro...o-9-spd-hg50-sora-tiagra-cassette/shimcass905
