[QUOTE 2563917, member: 30090"]Sorry, but a couple of things:
1) I'm not disputing that the lorry driver did not give priority, merely asking if there is a relevant piece of statue legislation that says you must give priority to traffic approaching from the right, so I'm unsure of the relevance of the rule that you have quoted.
2) Just to reiterate, the only thing I have questioned is that the cyclist was in the wrong approach lane and here is my cut n paste of the HC to back his up.
4. Roundabouts (184 to 190)
184
On approaching a roundabout take notice and act on all the information available to you, including traffic signs, traffic lights and lane markings which direct you into the correct lane. You should
- use Mirrors – Signal – Manoeuvre at all stages
- decide as early as possible which exit you need to take
- give an appropriate signal (see Rule 186, below). Time your signals so as not to confuse other road users
- get into the correct lane
- adjust your speed and position to fit in with traffic conditions
- be aware of the speed and position of all the road users around you.
[/quote]
77
You may feel safer walking your cycle round on the pavement or verge.
If you decide to ride round keeping to the left-hand lane you should
- be aware that drivers may not easily see you
- take extra care when cycling across exits. You may need to signal right to show you are not leaving the roundabout
- watch out for vehicles crossing your path to leave or join the roundabout.
As I also said before, Lane directions are advisory. So getting in the correct lane is a bit of a none issue. And really, it doesn't effect the outcome of the incident at hand.
