byegad
- NE England
The traps I use nearly cut the little beggars in half. I do lose peanut butter from the traps, but I know that it's the slugs that get to it. Mind you, the bigger ones set the traps off too.
only cost me a fiverYou can recommend it but at £60 I ain't bitin'![]()
thanks for the tip.Peanut butter is useless.
I’ve caught hundreds of the little buggers over the years. All using a raisins .
Wow. I tell you what, if I was a mouse I wouldn't want to run into him/her in a dark alley...If you don't want @Mo1959 's cat you're welcome to this one. They're big, not house trained and loud. Oh - and the photo shows their catching ability.
I'm trying that one too. Just one teeny tug, that's all I ask...thanks for the tip.
Will try.
But am somewhat alarmed by you having caught hundreds.
mm - do you have a pic - maybe it's the one I had no success with.We have small clear plastic box type traps that have a door at one end that they go into and the door shuts behind them. We never put anything in the traps. We put them outside along the wall and they go In and whamo.
We catch loads as well.
They work really well.
I've heard some of the outside ones also come in. Sneaky buggers, I wouldn't put it past 'em.why are you interested in catching mice outside? Why not leave them be?
two things about the rest of your post strike me:
@ too bloody mean to at least give the mice a gourmet treat.
@ why are you interested in catching mice outside? Why not leave them be?
That's not a trap, it's a bloody mouse caravan!
that looks kind of similar to the metak one I posted above.These have never failed us:
View: https://www.amazon.co.uk/Rentokil-Capture-Mouse-Traps-Loose/dp/B000TAUQPK
Longest time from feline deposition has been about 48 hours but usually less than a day and sometimes just minutes for voles. A generous daub of peanut butter at one end and a 20p coin taped to the other as a counterbalance aid.
We have three of these to hand, although I have got pretty nifty at simply rapidly grabbing the mouse alive in the 1.5 seconds you get from it being dropped to it to make a decision to leg it. Not for everyone - voles have very sharp teeth. Plus if I then throw it out of the nearest window, the cat promptly nips outside and catches it again.
One piece of advice - don't be tempted to check indoors if a closed one has something in it. If it does, it won't stay there long.
