Octet
I've just checked my tyres and I can push them down a small amount, so I thought I would give them a bit of a pump.
I took out the mini-pump for the first time, attached it to the Presta valve and I've started pumping.. and pumping... and pumping.
I understand that they would take longer as the pump is only small, but I've been pumping for about 40 minutes attempting to get only a small amount of air into the tyres and I just cannot get it to inflate.
I've checked that the valve is open, and I've gone through the instructions on the mini pump to the letter.
Am I doing something wrong?
Should the mini-pump get that tiny bit at the end?
How long should it take?
I've got the Bontragner Airrush Road mini-pump that can do both hand and Co2 pumping.
Thanks
(still need to get a track pump, it is on my things to do list)
Thanks
