02GF74
Last time I used a mini pump it broke in my hands and accidently punched the wheel and cut my hand.
Had an accident that is not your fault? Then call 0791 888 321
Advice to anyone with a mini pump, try it out so that you know it works and know how to use it before you really need to use it.
I would advise wiping the WD40 out of the pump and using a smear of Vaseline instead.
WD40 will rot rubber, and you'll be spraying a mist of it into the inner tubes.
