mickle
innit
- 53.933606, -1.076131
I'm not claiming any supernatural abilities but I never misjudge the speed of other road users. Especially cyclists.
There's actually a very simple way to do this if you're behind the cyclist. What you do is, you slow down until the gap between you and the cyclist is no longer shrinking, then you read the number off the big dial in the middle of the dashboard. [ edit: no, not the rev counter. no, that one's the oil temperature. look for the one that probably has markings between 0 and about 100 and has the legend "mph" on it ]That I have, that it is not always easy for a motorist to judge a cyclists speed
I'm a little concerned with the use of 'anticipated' here, if you're behind a vehicle with a relatively small closing speed there's little excuse as to why you couldn't gauge their speed fairly accurately.I then realised the cyclist was going a lot faster than I had anticipated; the road was a slight downhill gradient so he was probably doing 22-25mph. I was probably only going 5mph faster than him. Hence me putting a bit of a squirt on to make sure I can pull in in-front of him at a safe distance.
The road wasn't clear, it had a junction on it, something like that should be viewed in a similar manner to the road having a central refuge. The reason for this is that with side road so you can anticipate with a fairly high probability someone may pull out. Remember you're approaching the junction on the wrong side of the road, the driver won't be paying much attention to road to their left as it's unusual for anything to be there. Sure it's bad driving but it's also common habit.The road was clear ahead, the cyclist was not doing the speed limit, I was perfectly entitled to overtake. The problem arised when a car entered the road from a side road. Now unless I can predict the future there was no way for me to see that was about to happen!
This bugs me as well, it's nice to have a car that has a surprise overtake feature - it's very quiet but so quick. On occasions you can see people actually flooring it after you've basically passed them, likeTHis winds me up no end, the amount of times I have been following someone for miles at 45-50, I then overtake and find myself at 70 with them just behind also doing about 69, after a little while they will disappear as they drop back down to 45-50; why do so many drivers do this, are they trying to cause an accident?
. Much harder to do in the lotus which is loud, in fact dropping a gear often 'encourages' the driver to speed up a bit & move to the offside, it's a bit like "I'm not going to let you overtake"I think you've missed the point here. It's not that you can't overtake, it's that when you see a junction it should be treated in the same was as you would if there's a centre refuge there. It might be perfectly safe to overtake in the space provided it may not. The point is that you shouldn't be within the overtaking maneuver by the time you get to that junction.This was an urban road and like any typical urban road it had side roads coming off it and a junction at either end. If the view is that you can never overtake a cyclist because there is a side road within 200/300/400? yards then every other vehicle would permanently have to stick behind the cyclist because no overtake would ever be deemed safe.
I'm going to STRONGLY disagree here, I'll not go into the reasons why as that's another, heated, thread in its own right.In a perfect world there would be well maintained, wide cyclist only lanes on every road, with it being illegal to block these lanes.
In a perfect world there would be well maintained, wide cyclist only lanes on every road, with it being illegal to block these lanes. But we do not live in a perfect world, everyone has to share the road.
If he genuinely has no other way of judging the cyclist's speed (which was your claim not mine), what else do you suggest he do? Try and overtake anyway on the offchance?That is the stupidist thing I have read yet. So a car driver sees a cyclist in front of him, should slow down, match his speed, work out his speed and then decide to overtake.
Yes. But I seem not to have as much trouble judging the speed of other road users as you suggest I should have. Perhaps that's because I make the effort to, instead of assuming they're all dawdling along and that I'm "entitled to overtake"Do you actually ever drive?
I doubt it's malicious: I think they're just driving on autopilot and don't notice until they see another vehicle that they're going much slower than they could be.THis winds me up no end, the amount of times I have been following someone for miles at 45-50, I then overtake and find myself at 70 with them just behind also doing about 69, after a little while they will disappear as they drop back down to 45-50; why do so many drivers do this, are they trying to cause an accident?
